Question Fireboard and JDefender
17 years 9 months ago - 17 years 9 months ago #778
by wjnesbitt
Fireboard and JDefender was created by wjnesbitt
Hello. Hope I'm in the right place to ask this.
I'm having an issue with Fireboard. My moderator is attempting to test the forum by creating a new thread, but when he presses submit he gets the following error:
The action was stopped because of suspicion on PHP injection attack. The values that led to the stopping are templatePath=http://www.mysite.com/components/com_kunena/template/default.
I currently have JDefender installed and believe that it is somehow associate with this, but I don't know how to get beyond this error. This happens each time he attempts to create a thread anywhere in the forum.
Can someone please help? Thanks.
I'm running Joomla 1.0. Yeah, I know it's old (lol) but it's what I'm using for now. Thanks in advance for any help.
Last edit: 17 years 9 months ago by wjnesbitt.
- PetterSandvik
17 years 9 months ago #779
by PetterSandvik
Replied by PetterSandvik on topic Re:Fireboard and JDefender
Hi!
Add:
com_kunena::templatePath
In the no stop field in config, and it works
Add:
17 years 9 months ago #782
by wjnesbitt
Replied by wjnesbitt on topic Re:Fireboard and JDefender
Thanks, PetterSandvik!! That fixed it!
I put com_kunena::templatePath in place of com_kunena::templatePath in JDefender and now my forum is working perfectly.
Thanks again! You are a life saver.
- Vault Files
17 years 8 months ago - 17 years 8 months ago #8174
by Vault Files
Replied by Vault Files on topic Re:Fireboard and JDefender
Hi there
I'm having the same issue with Kunena (lol)
I have tried the rule com_kunena::templatePath in the exeptions of jDefender but it just wont work!
I know I should ask the creators of jDefender, but there site won't load ><
I managed to get this from google cache off of there site:
using the example code I tried several variations including:
orig string: domainname.com/index.php?option=com_kune...=6&catid=6&func=post
com_kunena::itemid
com_kunena::Itemid=6
com_kunena::post
things like the above.
Any suggestion would be greatly appreatiated
Written by Dmitry
Simply insert double colon separated name of component and value name that JDefender triggered.
For example this link:
www.site.com/index.php?option=com_xxx&task=value_jdefender_blocks
The exeption will be looks like:
com_xxx::task
The exception could be added for PHP and SQL injections only.
com_kunena::itemid
com_kunena::post
Last edit: 17 years 8 months ago by Vault Files.
