Question Preview problem
17 years 8 months ago - 17 years 8 months ago #6300 by artnco
Preview problem was created by artnco
hello i have this problem : when i click on the preview botton, nothing happened there is a chargement but i wait a few moment , nothing, do you have an idea ? i try with a simple template its the same problem
thanks
Last edit: 17 years 8 months ago by artnco.
17 years 8 months ago #6352 by Matias
Replied by Matias on topic Re:Preview problem
You may have javascript conflict with your Joomla template / modules. Check if other JS buttons work, like adding bbcode or smileys.
You may also want to switch back to rhuk_milkyway and try to disable all extra modules. It may help to track down the problem.
17 years 8 months ago - 17 years 8 months ago #6395 by roland76
Replied by roland76 on topic Re:Preview problem
Do you use sh404SEF or similar?
If yes try: www.kunena.com/forum?func=view&catid=13&id=754#4917
Last edit: 17 years 8 months ago by roland76.
17 years 8 months ago #6577 by artnco
Replied by artnco on topic Re:Preview problem
thanks but on this page : www.v2.tele47.fr/index.php?option=com_kunena&Itemid=110
i have only 1 module i try smiley its ok
thanks
17 years 8 months ago #6848 by artnco
i use artio joomsef when i disable the artio plugin for meta the preview is ok but the problem is that i must use this plugin active !
thanks
17 years 8 months ago #6952 by Matias
That previous fix by roland should work with Artio Joomsef too..
