Question Limits for external images. How does it work?
17 years 8 months ago #5039 by rinuccio
On my site I have set limits for height and larhezza image
500 * 500
Now,
If loading from my computer a bigger picture does not load.
Ok!!!
But if I post the link to an external image, the image that remains on my site has different dimensions than those set in the configuration
ES:
In this post:
www.indafun.it/index.php?option=com_kune...atid=10&id=5562#5562
In this post the images do not meet the dimensions set. Why? :huh:
17 years 8 months ago #5049 by grumblemarc
There are also filesize limitations for uploaded files. Did you configure that as well?
17 years 8 months ago #5092 by rinuccio
I did not understand ...
I put a limit. this limit is observed only when loading an image from the PC.
External images do not take into account this limit.
17 years 8 months ago #5145 by Matias
Of course they do not.
Kunena does not check external links and should not do that for security reasons.
If it would do the check for every file, I have an attack that will render your site useless. Just link 10M file to a post and make an automatic script to fetch that page.
Results: your site loads very, very slowly and soon (in 2-5 days) it hits GB limit and will be offline rest of the month.
17 years 8 months ago #5158 by rinuccio
But the external images are scaled equally.
But these new dimensions do not take account of my settings
ES:
www.indafun.it/index.php?option=com_kune...atid=10&id=5562#5563
the actual picture has this size 600px × 799px
www.ilmessaggero.it/MsgrNews/HIGH/20090220_rihanna1.jpg
in the post has this size 405px × 539px
In settings where the limit is 500 * 500 why the image is resized (anyway) but with different dimensions? :huh:
Thus, the external images are resized anyway.
But by what criterion? :dry:
17 years 8 months ago - 17 years 8 months ago #5185 by Matias
There are two different settings: one is max allowed image size and the another is max width they can have in the forum. If you change the limit to 2000x2000 px and look at the page, the image will be scaled down.
Yes, this needs to be changed -- it's legacy feature from FireBoard.
The criteria is there because of css limits. Try to change Textarea Width (I think it's this one) to 2000 and load that large image. It will break your layout.
Last edit: 17 years 8 months ago by Matias.
