Question Problem with display of text
- Sethu
First of all thanks for such a great product i am blown away by the quality and the service that comes with, You guys are the BEST.
I have intalled 1.0.8 , and i am having trouble with ' , every time there is a ' a slash \ apears with it. Is there a fix for this ?
Thanks for all the help
EX : you don\'t give sufficient detail.
- Sethu
Where do you find these slashes? Screenshots?
- Sethu
Check that you don't use your own template -- this is a template issue.
Yes it's not Kunena , i had done a cut and past for that specific test. i tested in Kunena and its seem fine.
Thanks a lot
Problem solved
