Question Kunena 1.0.8 quick reply issue?
17 years 9 months ago #4333 by Baze
well the folder "macedonian" is inside the default_ex/images folder and it only contains images (icons, smilies...) all other files are left as they were with the installation.
thanks for your help
17 years 9 months ago #4363 by johnnydement
all button images are language dependant... if you're not sure if they are in your macedionian folder, backup it, copy and rename your english one to macedonian, and reupload and overwrite the macedonain you backup, if any image was missing, it shouldn't be anymore ;)
17 years 9 months ago #4376 by Baze
Well the point is that images exist (i even tried restoring the original one) but the quick reply button simply doesn't works on my forum with Firefox 3.0.6 :S
i know it sounds crazy but it's happening...
i'll send you pm with info for the site so that you can check it out yourself.
17 years 9 months ago #4569 by Baze
Ok, i assume it has something to do with my template (im using rocket theme bentobox), because in the first place i had to remove several "clear:both;" lines inside the css in order to show kunena properly.
i'm using firebug to solve the issue and so far i've noticed this line:
<div id="post id here" class="switchcontent" style="display: block;">
and i've found the line inside message.php but without the display: block style. Where can i find it??
i think altering this will solve my problem...
17 years 9 months ago #4576 by Matias
Did you look at the right template?
Can you give me a link to your site?
17 years 9 months ago #4582 by Baze
Sent you PM
thanks for your effort!
