Question PM and 2 Languages
Do I need to install additional component?
Appreciate if someone can show me how to add this into my forum
Another question, I'd like to make my forum have multi-language
function. That means when users choose the language - the system
message and menu will appear accordingly. Is there any way
I can do so?
- johnnydement
- Elite Member
- Thank you received: 5
For language, yes, kunan picks tghe language your user has selected for joomla, and applies it also to kunena, if you have it also, and shares name (eg: joomla lang name is german, kunean must have a kunena.german.php file
May I ask which of the PM extension is better? I need a stable 1 with normal feature will do.
Not quite understand the language thing you mentioned above. Does it mean I have to download a language file and install to my joomla? If it's the case, how to do so?
Thanks!!
- johnnydement
- Elite Member
joomla has languages as well, so, yes, you need to have joomla language files, and kunena language files
your users can select wich language to use in your site, from the ones you have installed, from a dropdown box in their joomla profile
going to the user profile?
Sorry for asking too many questions
