Question Spotlights/Sticky doesn't work.
17 years 9 months ago #3354 by kootjoo
I have got a problem with some of the buttons. At the bottom of topic page.
With some of the buttons the id of the topiv is not added. For instance the reply to button works great:
com_kunena&Itemid=133&func=post&do=reply&catid=54&replyto=34
But for instance the Sticky Button
com_kunena&Itemid=133&func=post&do=sticky&catid=54&id=
The id at the end is missing. I'm using the default_ex template.
Any hints on how to solve this problem would be great.
Best regards,
KooTjoo
17 years 9 months ago - 17 years 9 months ago #3358 by Matias
They have been fixed already in our SVN. Release will be out in less than two days.
Last edit: 17 years 9 months ago by Matias.
17 years 9 months ago #3726 by kootjoo
Thanks, I downloaded SVN and problem is solved!
