Question \ gets stripped from posts, in code tag or not
17 years 9 months ago - 17 years 9 months ago #2643 by cheathamlane
Hi there:
Lines like:
c:\\Users\xxx\Documents\Spincontrol
Become:
c:UsersxxxDocumentsSpincontrol
This happens whether or not the text is wrapped in a code tag. Acutally, wrapping text in a code tag ( [ code ] minus spaces) doesn't appear to do any highlighting at all.
Ideas?
Thanks!
Patrick
example post:
www.panosalado.com/forums?func=view&catid=16&id=17#31
Last edit: 17 years 9 months ago by cheathamlane. Reason: added link
17 years 9 months ago #2644 by johnnydement
This has been fixed in SVN and will be on next 1.0.8 release ;)
17 years 9 months ago #2751 by cheathamlane
Hey there:
Both issues are fixed, or just one of them? (\ stripping or code highlighting)
Cheers,
Patrick
17 years 9 months ago #2782 by johnnydement
mmm, If I remember corerctly, highlighting was introduced as an option in FB1.0.5, due to some users not wanting it to be mandatory...
stripping is fixed, the other should not exist any issue :blink:
17 years 9 months ago #3171 by cheathamlane
Thanks!
When I wrap things in a code tag, the text gets offset (like a quote does), but no highlighting happens...
Cheers,
PAtrick
17 years 9 months ago #3172 by fxstein
You need to select code highlighting in the Kunena backend configuration. By default it is turned off.
