Idea Move a single post option
17 years 3 months ago #24672 by lex thoonen
I'd like to be able to move a single post to another forum, without splitting or merging.
I found the info underneath, but I'd prefer it to be a lot easier.
Thanks!
To move a post to another topic, you only have to use the merge-function. But this does only work, if both threads are in the same forum.
If you want to move a post to a topic, that is in another forum, unfortunately you must take a laborious way:
Example:
Forum 1, thread start, post test
shall be moved to
Forum 2, thread goal.
Solution:
Create a new thread dummy (in Forum 1)
Merge post test with thread dummy (leave NO coy in old thread)
Move thread dummy to forum 2 (leave NO link to moved thread in old forum)
Merge post test with thread goal (leave NO coy in old thread)
Delete thread dummy.
Time to create page: 0.095 seconds
