Question Boardcode bbCode Help - Tip box not changing on icon hover
17 years 4 months ago #22630 by itgl72
Trying to figure out how to track down an issue with perhaps FIREBUG to determine what is causing this conflict.
I'm specifically needing some help in the fb.posthint area. It doesn't matter if I am using my moc kunena template or the default_ex template. When I hover over the icon's for B, I, IMG, URL, etc the bbCode Help - Tip box does not change to tell a user what the code is going to do.
Is there something I can look for to help track this down? Like I said I have firefox's firebug installed and use it plenty for CSS but I am not much a javascript coder.
17 years 4 months ago #22632 by @quila
17 years 4 months ago #22637 by itgl72
THANK YOU... I hate it when you search, and don't fine what you need after drilling 10 pagination's deep looking for an answer. I'll try the options there at that post. Looks like it may be my issue.
