Question Problem with Login Page on Forums
17 years 9 months ago #2236 by bawobogo
When I click the login page of my forums, the login page shows up, but the forms don't.
www.epitaph-site.com/index.php?option=com_user&view=login
Please help.
17 years 9 months ago #2251 by Matias
Do you use any 3rd party login plugins?
17 years 9 months ago #2272 by holgenoni
i have a similar problem so i don't want to open a new thread.
I am using yoologin on the top of my side.
And now since i updated fireboard to kunena, it's not possible to use the login when the forum is loaded.
So when i try to login somwhere else on the side, it works.
When i go first to the forum and then try to login, the side reloads, and nothing else happen.
I have created a user:test with pw:test so you can try it your self.
And here is the link to my side.
17 years 9 months ago #2285 by grumblemarc
Sounds like an issue you might want to address with the YooTheme team. Possibly they may need to update the module. Could just be a simple javascript conflict. They tend not to update their old offerings with new libraries.
17 years 9 months ago #2465 by holgenoni
well, i have tried to address this issue to the yootheme team,
but i haven't found a way to contact them.
It looks like you have to be a member to contact them!
17 years 9 months ago #2467 by grumblemarc
Like I said. It is most likely a javascript conflict. Possibly with the Default_ex template. Try a different Kunena template and see if the problem persists.
