Question Adsense code
17 years 9 months ago #2180 by triangleguy
Adsense code was created by triangleguy
How do I update the Adsense code with my own code? I can't find where this is located in the files. Also, if I wanted to remove ads entirely, how might I do that? Thanks.
17 years 9 months ago - 17 years 9 months ago #2202 by Matias
Replied by Matias on topic Re:Adsense code
In the end of components/com_kunena/templates/default_ex/message.php.
Ads are managed by another component, so if you don't use the them, there aren't any. :)
Last edit: 17 years 9 months ago by Matias.
17 years 9 months ago #2213 by fxstein
Replied by fxstein on topic Re:Adsense code
We will provide a how to with the new functionality in K 1.0.8. It has been rewritten. It is totally optional if you want to use it. It is not limited to adsense but displays any Joomla module after each post as a separate modul position, as well as inside the profile box.
