Question When making a post, I get a mostly white page.
I have already added the following to php.ini but that didn't help.
upload_max_filesize = 32MB
post_max_size = 24MB
memory_limit = 32MB
Sorry about your issues.
In order to ghelp you we will need at least some of the basic configuration settings and versions you have installed.
In most cases this is caused by additional moduls or components that get installed.
If you recently added a new plugin, module or component, try to disable it to see if the problem goes away.
A good place to start looking for the problem is your web servers error log. You hosting provider will be able to assit you in finding that error log. In there you will find Warnings, Errors and Fatal Errors.
These ususally point you straight to the problem at hand.
Hope thsi helps!
fxstein
I have attached the logs and a screenshot of the config screen.
Attachment logs.txt not found
