Question Integration Problems
17 years 9 months ago #1670 by johnnydement
FB != kunena ;) so until azrul or any other extension gets a new build that supports it, unless you hack it, better not to use ;)
For any site using jomsocial, I would suggest it to use as base for the rest of extensions, same for CB, you want your community to be the source of info for the rest,
are you using joomla default prefix "jos_" or a custom one?
17 years 9 months ago #1681 by fxstein
Replied by fxstein on topic Re:Integration Problems
henryca wrote:
ISSUE 1
This is what I got when I clicked on the one with the blank name:
Fatal error: Unable to load user profile.\nDB function failed with error number 1064
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1 SQL=SELECT * FROM jos_fb_users LEFT JOIN jos_users on jos_users.id=jos_fb_users.userid WHERE userid=
SQL =
in /home/cheryl/public_html/cah/components/com_kunena/lib/kunena.debug.php on line 37
ISSUE 2
There is no synchronization even though:
1. In jomcomment, I selected get avatar from fireboard (kunena)
2. in myblog, I selected get avatar from fireboard (kunena)
3. in Kunena, I selected to get profile info from Jomsocial etc.
4. in Jomsocial, it synchronizes successfully with Joomla user management
END RESULT
From my blogs, I cannot link directly to my my jomsocial profile
From my comments I cannot link directly to my jomsocial profile
From blogs and comments there is no avatar though in Jomsocial all profiles have avatars
From Kunena, I can link directly to my Jomsocial profile - just no avatar; I have to reupload one.
So there isn't synchronization to 100%; further more when I cick on Synchonize Users it gives me nothing... no feedback saying that it did or anything...
So whenever u can help I'd appreciate it. I love Kunena - especially the name :)
c
Not sure I understand issue #1 how did you get there?
As for #2:
That is not how integration of profiles work. All components MUST point to the same profile profider. There is no such thing as profile forwarding between components. Components 1,2 & 3 should all be set to get their profiles and avatars from jomSocial.
Also make sure the avatar source in Kunena is set to jomSocial as well.
That should take care of most of your issues.
Hope this helps!
fxstein
PS: Glad to be in a 24x7 team - somebody is always awake around the globe! B)
