Question Help with Latin special letters ( č ć š đ ž )
_____________________________
First of all, want to say that this component is GREAT!
but i have a little problem, i'm in balkan so i have more characters like Č Ć Ž Š Đ its a utf8_unicode_ci coding... when im typing a new post mesage ... it's empty if i put one of those letters
My version is 1.0.9, i looked in to docs.kunena.com/index.php/Empty_messages_bug
but this didnt solve my problem.
Does anyone have any idea...
thanks
Thanks lot for quick answer.perhaps this can help you:
www.kunena.com/forum?func=view&catid=93&id=13042#13042
I check my tables collation, there is obout 20 of them with latin1_swedish_ci collation, the rest of them are utf8_unicode_ci.
Is there any way to change all tables and fields in them to utf8_unicode_ci collation?
I tray to change database collation to utf8_unicode_ci, but tables stay the same
try Phoca Changing collation tool
extensions.joomla.org/extensions/tools/d...e-tools/5184/details
Regards
Didnt helpHi Nijaz,
Regards
This is the error
Warning: mysql_connect() [function.mysql-connect]: Access denied for user 'admin'@'localhost' (using password: YES) in /home/mosta0/public_html/tool_phoca_changing_collation/index.php on line 45
Back to the main site
Database error.
Is there any special settings to set before he can change collation?
