Question What happens to posts of deleted users
  • webrus
  • webrus's Avatar Topic Author
  • New Member
  • New Member
17 years 9 months ago #1368 by webrus
Before I have I try I prefer to ask:
What happens to the posts of users that are deleted. And further on - if their post persist, what happens when I click the username?
17 years 9 months ago #1431 by fxstein
To be honest - I have not tried. The post definitely stay in the database. As for links, they will most likely point to never never land and will most likely put you back onto the homepage.
Our new class design for versions 1.1 and above will allow us to specify default behavior for such situations much better.
Until then a bit of manual cleanup might be required. One could remove the user-id for such posts and they would look like guest posts without a user profile link.
Hope this helps!
fxstein
Time to create page: 0.101 seconds
