Question Emoticons, not responding....
17 years 7 months ago #13493 by zzbomb
When making a post here you just click the emoticon you want and it gets added to your site.
When i clicking one it at my site : gamerunited.com/ it does nothing, however you can still get it to work if you know the thing for it.
Any ideas why this might be happening?
17 years 7 months ago #13509 by Matias
There may be javascript conflict in your site. Please try your site with default templates in all Joomla modules disabled. this way it's easy to try one by one which one is causing you the grief.
17 years 7 months ago #13572 by zzbomb
OK, thanks, that fixed it, turns out it was part of my template...
New problem though,
This part still doesn't work, the "More smiles" Button does not open anything,
I will try messing with some things, other plugins, admin section, but if you have any advice i would be grateful.
17 years 7 months ago #13576 by Matias
Others may know better solutions, but try to use FireBug to track down the problem. It's really nice tool for FireFox.
17 years 7 months ago #13660 by zzbomb
Hm, i figured out that Rokbox, a plugin i have is causing it to not open them....
Im not sure what i can do about this.. Rokbox is part of my login system and i REALLY dont want to get rid of it, im going to look for a new version of it or something, but if you have any ideas it would be great.
17 years 6 months ago #14027 by Matias
Contact the authors of the plugin. There have been too many issues with it -- maybe the devs will hear you if there are many complains. :)
