Question Community system on kunena.com
17 years 7 months ago #12961 by Denizar
Hi. On my site when I click on "Register" on the forum, it directs me to
..../index.php?option=com_user&task=register&Itemid=61&lang=en
rather than
..../index.php?option=com_comprofiler&task=registers&lang=en
Is this because I picked "Kunena" in User Profiles under Forum Configuration?
I am using Community Builder and didn't like their Profile page and avatar system so I want to use Kunena's, but I want to still be able to use Community Builders Register and Login and also Lost Password pages. Is this possible?
Oh, one more thing. I really like the community system on this website. Does anyone know which community manager this is? Is it Community Builder? Thanks a lot in advance.
17 years 7 months ago #12964 by xillibit
on kunena.com it's joomsocial which is used, but it's not free :( .
17 years 7 months ago - 17 years 7 months ago #12978 by sozzled
The short answer is yes, you can use the CB registration and login functions.
The longer answer is that, in order to overcome the confusion that the Kunena forum page presents your users by having a link to the standard Joomla registration and login functions, it may be wise to remove the Kunena "profilebox" element.
I recommend you look at www.kunena.com/forum?func=view&catid=12&id=10184#10188 for the reasons why and for the technique on how to work around the problem.
Last edit: 17 years 7 months ago by sozzled.
17 years 6 months ago #13545 by Lintzy
rather than
You could ask in this thread for Kunena 1.0.9. I guess the solution there is for Kunena 1.0.8 yet.
www.kunena.com/forum?func=view&catid=114...mit=10&start=10#6649
