- Thank you received: 565
Question Kunena 1.0.7b Known Problems and Answers
Could you make a list of all known problems in which there is a easy solution? You can start with your own issues.
Here are the rules:
* Only one message per problem, all extra messages and questions will be moderated away!
* Write a descriptive subject: "Users cannot change their Avatar in My Profile"
* Message contains two parts:
-> Question: Short description of what is wrong
-> Answer: Best known solution for the problem
INDEX:
Remove threaded view
Broken pages: latestx & showcat
My Profile Avatar upload page broken
Attachments are broken in Windows server
If you want to disable it now, do this (default_ex):
components/com_kunena/template/default/plugin/myprofile/myprofile_set.php:
Comment out line 38:
Comment out lines 41-48:
components/com_kunena/template/default_ex/fb_layout.php:
Comment out lines 206-216:
Comment out lines 221-232:
and then run SQL query (replace jos_ if you have different prefix in Joomla):
This bug happens only if your Joomla installation is using custom prefix (not jos_).
Solution:
components/com_kunena/template/default_ex/latestx.php:
Find and replace all "jos_fb_" with "#__fb_".
components/com_kunena/template/default_ex/showcat.php:
Fatal error: Call to undefined function get_dirs() in components/com_kunena/template/default/plugin/myprofile/myprofile_avatar_upload.php on line 264
Solution:
Get latest version of these files from our SVN:
joomlacode.org/gf/project/kunena/scmsvn/...lugin%2Fmyprofile%2F
.. and put them into: components/com_kunena/template/default/plugin/myprofile/
Solution:
Replace following lines in componenets/com_kunena/template/default/post.php:
Line 286, fixes saving image location:
Line 296, fixed saving file location:
Line 1926, for missing files:
- hartleyheaton
I set my profile to show latest first which was fine until the topic went over more than one page. Only the first few posts are shown, in reverse order, but the latest posts are not shown and there does not seem to be any way of changing pages.
I am going to upgrade to 1.0.8 and will test it again.
