Question Moving posts (messages) between topics Renew
17 years 7 months ago #12478 by princ007
Hi Everybody!
I would like to move just a few post from a topic to another topic! I found answer what Lintzy wrote, but i would like to ask in a newest version 1.0.9. can i move directly the posts between the topicks!
I try slpit function but it can't moves the post to another existing topic!
Thanks!
Yours Sincerely!
17 years 7 months ago - 17 years 7 months ago #12480 by core2
I guess this is the same question you posted in post: #12363 ? If that is the case please don't start several threads about the same problem.
I don't know which of Lintzy's answers you are referring to?
After splitting out the messages you want to move, you can use the merge function to glue them into another thread. You must do it in two operations. It isn't the smoothest way of doing it, but until someone have a solution that is maybe the way to do it?
I hope this answer your question.
Visit the Kunena documantation .
Last edit: 17 years 7 months ago by core2.
17 years 7 months ago #12588 by princ007
17 years 7 months ago - 17 years 7 months ago #12593 by johnnydement
Please, don't use the split/merge functions. Theya re old fb code, and thye are poorly coded...
They can broke any forum with ghosty messages, missleading id's,...
Redoing them is one of our priorities after nativeness...
I would suggest sql administration for this, or simply, copy&pasting ;)
Last edit: 17 years 7 months ago by johnnydement.
17 years 7 months ago #13019 by princ007
Thanks!
I will waiting while this will be good and will be a MOVE function in the new kunena version!
Yours Sincerely!
