Question emoticons not working if there is no preceeding blank
17 years 7 months ago #12316 by kalli
hi all,
i posted somewhere else on the forums as well as someone reported same issue.
I'll try here as well, since this seems to be the correct forum for it.
the following did work in Fireboard but does not wok with Kunena 1.0.8 and 1.0.9
I assume this board uses version 1.0.9
here the error
smiley with blank :laugh:
smiley without a blank:laugh:
Fireboard (i think I used 1.5) would show both smileys, this version only shows when there is a blank between the word and the smiley
17 years 7 months ago #12325 by Lintzy
This seems to be fixed in 1.0.9.
You mean this :) :) :) :) :)
Several smilies in one row without blank between?
I have installed 1.0.9 and there it works. On 1.0.8 it did not work.
17 years 7 months ago #13045 by Matias
Smileys do not work if they are attached into a word:
Here is what I mean:someone could write this and have a smiley like this:
Here is what I mean :s omeone could write this and have a smiley like this!
And that's not what we want.. And some languages have smilies in the words:
TV:stä tuttu juttu on 2:s paras tuttu
TV :s tä tuttu juttu on 2 :s paras tuttu
If you add a smiley in the editor, it will be wrapped by space and works.
17 years 7 months ago #13050 by grumblemarc
An option to disable emoticons in a post is needed.
17 years 7 months ago #13111 by Matias
I meant that we have fixed smiley bug for some languages so that it does not add smileys attached to the words.
You can see, that the first rows do not contain smileys, but the second one (made by clicking :s smiley icon on the editor) works as expected.
17 years 7 months ago - 17 years 7 months ago #13280 by kalli
interesting discussion.
now i get what actually was fixed. "no blanks between two smileys"
the same problem we have is when there's no blank between "word and smiley".
the users on our forum are just used to the fireboard behaviour where it actually picked up smileys when they were at the end of the word:laugh: <-this would show as smiley in fireboard
but if its causing chaos in other languages that they use things like:s then ya. leave as is :-)
Last edit: 17 years 7 months ago by kalli.
