Question No green template + using legacy mode
17 years 7 months ago #11202 by starfly
Hi.
I just downloaded the latest version and installed. Smooth as silk. No probs with the install - which is a sign of a good Joomla Component right away... But:
Because my site is green I wanted to use the 'Default_Green' template option, so I selected 'Default_Green' and when I load the forum, no template related images appear and I get an error at the top: "pat-Warning: Template 'kunena-header' does not exist."
If I set it to default template, the forum appears fine, but in blue which, doesn't quite work on a green site.
I've searched all over, including Google, for how to make the default_green template work and am lost.
Second issue: I added the SEF SH404 file and the forum has nice SEF URLS, but inly when running in legacy mode. Is that normal?
Thanks.
Martin
17 years 7 months ago - 17 years 7 months ago #11205 by core2
Kunena 1.0.9 are designed for J1.0 native, but runs on J1.5 with legacy plugin enabled. If you are talking about Kunena 1.5.0 alpha it is only for testing purpose and no support is provided.
If this is a bug report please report in this thread: www.kunena.com/forum?func=view&catid=8&id=10674 for K1.5 bugs.
Visit the Kunena documantation .
Last edit: 17 years 7 months ago by core2.
