Question Wrong titles
Wrong titles
i use Kunena together with SH404 and my titles look this way:
my-sample-post-in-forum | forum-name | Site name
so you can see all posts and categories are written in small letters with dashes between words even forum name is wrong.
Turning SH404 off for Kunena helps but i want to have SE friendly links.
I use fireboard extension for SH404 (renamed to Kunena).
Thank for your help.
PS: you can see it here:
lovestoryblog.com/index.php?option=com_kunena&Itemid=196
In addition we strongly recommend against the use for 3rd party SEF components for the forum. It will eventually slow your site down to a crawling halt. The overhead gets exponentially worse, the more posts and threads you have.
- woonydanny
- Elite Member
- Thank you received: 22
Does this also apply to default J1.5 SEF turned on?
still wish that i can write my forum signature through a jomsocial plugin and do it from my jomsocial profile
No Joomla internal SEF is fine. It does not require queries or memory caches to work.
Hope this helps!
- woonydanny
- Elite Member
