This is not a support forum for any of the products contained herein. For product support you should visit the developer's website.
The information given in this category is intended to guide users who want to use various third-party products with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of other Joomla extensions.
Question TreeK. Tree-Shell for Kunena Forum
4 months 2 weeks ago - 4 months 2 weeks ago #235092 by lemur
Download and Installation of TreeK
TreeK Free can be downloaded by clicking on the link GitHub Releases .
TreeK Pro is distributed separately
for €20. and can be ordered through the menu item  Get TreeK Pro .
Installation
TreeK is installed as a Joomla package.
Requirements
  • Joomla 5.4.x, 6.0.x, 6.1.x.
  • Kunena Forum 7.x.
  • A working Kunena installation before installing TreeK.
Install TreeK (Free and Pro)
  1. Download the latest TreeK package.
  2. In the Joomla control Panel, go to System -> Install -> Extensions.
  3. Upload and install the TreeK package ZIP.
  4. Open System -> Plugins and make sure the TreeK AJAX plugin is enabled.
  5. Open Kunena -> Templates and activate the TreeK template.
When Trick Pro is installed, two tables are created in the website’s database, which support the saving and restoration of Trick settings.
After Installation
In Kunena's Recent Topics tab, the Replies number for topics with responses is clickable and highlighted in color. Clicking this number opens the topic's post tree.
If you have already entered a topic, you can access the post tree by clicking the tree icon located in the header of each post.
Use the settings button in the tree window to adjust the visible tree.
Uninstall TreeK (Free and Pro)
1. In the Joomla control Panel, go to Components -> Kunena Forum: Templates
Switch the default template from TreeK to another one (e.g., Aurelia).
2. In the Joomla control panel, go to System -> Manage -> Extensions.
3. Select the TreeK Package row and perform the Uninstall action.
If the TreeK template is set as the default at the time of uninstallation, the process will be blocked, and a warning message will appear.
The TreeK tables are removed when the package is uninstalled. No traces of TreeK remain on the site.
Before installing TreeK Pro, it is recommended to perform a test installation and uninstallation of TreeK Free.
Updating
Install the new package over the old one using Joomla extension installer. User settings are preserved.
Troubleshooting
If the tree does not open:
  • confirm that the TreeK AJAX plugin is enabled;
  • check whether the current Kunena template is TreeK;
  • confirm that Kunena is installed and working;
  • clear Joomla and browser cache.
Detailed information about TreeK can be found on the dedicated website treek.support .
Signature:
Many thanks to Rich and the other advisors.
Last edit: 4 months 2 weeks ago by lemur.
The following user(s) said Thank You: 9themestore
4 months 2 weeks ago #235093 by 9themestore
Hi Lemur,
I tried installing and configuring the free version, but the tree structure didn't display as you instructed. I think, I need to buy the Pro version to see that.
However, do you have a demo link for the tree structure display?
4 months 2 weeks ago - 4 months 2 weeks ago #235094 by lemur
Hi 9themestore,
I am very sorry to hear that the installation of Treek Free didn't work out for you.
Since you didn't provide specific details, I need to ask a few questions:
1. Did you download Treek Free from JED ? Please try downloadiit again.
2. Did the installation complete successfully, and did you enable both the plugin and the Treek template (completing all the necessary "configuring" steps)?
3. What do you mean by "the tree structure didn't display"? If a modal window appears and something goes wrong, an error message explaining the issue should show up instead of the tree. Please let me know what that message says.
4. Which version of Kunena did you use? TreeK has been tested and works 100% on K7.0.4 and K7.0.5.
And yes, I "have a demo link for the tree structure display".
Detailed information about TreeK can be found on the dedicated website treek.support . There is a special example on the forum of this site.
I hope the issue gets resolved at this stage.
Thanks for the feedback.
P.S. From the documentation:
Troubleshooting
4. Если, несмотря на это, проблема не устранена, проверьте журналы `administrator\logs\1.treek_install` и `administrator\logs\1.treek_ajax`.
Signature:
4 months 1 week ago - 4 months 1 week ago #235102 by lemur
The TreeK  Free and TreeK Pro applications have passed review in the Joomla! Extensions Directory and have been officially published there.
I have no doubt that the ability provided by TreeK to conveniently follow discussions on forums based on the Kunena platform will significantly enhance the experience for end users.
Details:  treek.support
Signature:
Last edit: 4 months 1 week ago by lemur.
3 months 3 weeks ago - 3 months 3 weeks ago #235127 by lemur
The Version: 2.0.5  TreeK  Free  and  TreeK Pro  have been published on Joomla! Extensions Directory
Compatibility update for Kunena 7.0.6 and 7.0.7.
Replies counters in more topic lists now open the TreeK window
“Show post excerpt” was renamed to “Show post beginning”.
Improved hints for guest users in Pro settings.
Minor quote and manifest fixes.
Signature:
Last edit: 3 months 3 weeks ago by lemur.
3 months 1 week ago - 3 months 1 week ago #235154 by lemur
The Version: 2.0.6   TreeK  Free   and   TreeK Pro   have been published on Joomla! Extensions Directory
Compatibility update for Kunena 7.0.8.
TreeK should be installed again after updating Kunena.
Signature:
Last edit: 3 months 1 week ago by lemur.
