This is not a support forum for any of the products contained herein. For product support you should visit the developer's website.
The information given in this category is intended to guide users who want to use various third-party products with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of other Joomla extensions.
Solved CjBlog issues with Kunena
13 years 1 week ago #150430 by matps
Hi There,
Firstly, I've read www.kunena.org/forum/K-2-0-General-Quest...ad-this-first#127255 and tried all the suggestions given in www.kunena.org/docs/Common_causes_of_Moo...29_issues_and_Kunena
However I am still having issues with being able to edit a users profile (I also have the issue where if I can on a user's name instead of viewing there profile it gives me the url ending forum/recent#)
I also cannot use the the 'Profile' tab unless I change it to 'not intergrate' under the Kunena 'Profile' menu item.
My website is www.craftkeg.com/index.php/forum/index and I've tried numerous options of disabling jquery and changing the template from beez5 to atomic and nothing has worked.
I've also used Firebug and viewed the page source and Kunena seems to be loaded before Hikashop, the other plugin I'm using.
Any suggestions would be greatly appreciated.
Kind Regards,
Matthew
13 years 1 week ago #150431 by matps
Replied by matps on topic CjBlog issues with Kunena
htaccess: Missing | PHP environment: Max execution time: 120 seconds | Max execution memory: 128M | Max file upload: 128M
Joomla default template details : beez5 | author: Angie Radtke | version: 2.5.0 | creationdate: Unknown
Kunena default template details : Blue Eagle | author: Kunena Team | version: 3.0.3 | creationdate: 2013-10-20
Kunena version detailed: Kunena 3.0.3 | 2013-10-20 [ Bifrost ]
Plugins: None
13 years 1 week ago - 13 years 1 week ago #150432 by sozzled
Replied by sozzled on topic CjBlog issues with Kunena
G'day, matps, and welcome to Kunena.
The bigger problem is what happens when people click a username in your forum. This does not look like a Javascript issue to me. This looks more like a Joomla menu problem.
1) Learn how to implement Joomla SEO properly by reading Search engine optimisation (SEO) in the Wiki.
2) Learn how to use a standard Kunena menu with Kunena menu issues .
3) J! 2.5.11 is out-of-date, vulnerable to security issues, and not supported by Joomla. You should update to J! 2.5.16.
Last edit: 13 years 1 week ago by sozzled.
13 years 1 week ago #150434 by matps
Hi There,
Thanks for the information, but I'm afraid it hasn't helped too much.
1) I tried running through the pointers for Joomla 2.5 but changing 'Use URL rewriting' to yes causes the menu to have a 404 error.
2) I deleted all menu instances and created a new menu with the method provided.
3) I've upgraded to 2.5.16.
I'm confusing with how this isn't a Javascript error when everything on the forum about not being able to edit a user profile suggests that it's javascript related?
13 years 1 week ago - 13 years 1 week ago #150435 by sozzled
matps wrote: 1) I tried running through the pointers for Joomla 2.5 but changing 'Use URL rewriting' to yes causes the menu to have a 404 error.
You will get 404 errors if you do not gave a valid .htaccess file. It's all explained in the article I referred you to.
13 years 1 week ago #150436 by matps
I'm just looking at my .htaccess now and it all appears to be fine. I assume changing it to .htaccess! means it doesn't need the .txt on the end still?
Time to create page: 0.156 seconds
