This is not a support forum for any of the products contained herein. For product support you should visit the developer's website.
The information given in this category is intended to guide users who want to use various third-party products with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of other Joomla extensions.
Solved Easyblog module causes Kunena Latest to not display avatar?
13 years 2 months ago #148104 by Tryweryn
Hi i had the latest post mod showing avatars. Anywhere I add the easeyblog show module on the site seems to cause the latest posts mod to stop showing the avatars. Any ideas please? It can be seen on www.britmovie.net
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : yoo_nano3 | author: YOOtheme | version: 1.0.7 | creationdate: Unknown
Kunena default template details : Blue Eagle 2.0 | author: Kunena Team | version: 3.0.2 | creationdate: 2013-08-18
Third-party components: Jomsocial 3.0
Plugins: Search - Kunena Search 3.0.1 | JomSocial - My Kunena Forum Menu 2.0.3 | JomSocial - My Kunena Forum Posts 2.0.3 | JomSocial - Kunena Groups 2.0.3
Modules: Kunena Latest 3.0.1
13 years 2 months ago - 13 years 2 months ago #148109 by sozzled
I'm about to make a wild guess based in part on your configuration settings and based on another discussion that we're having on this forum about the Kunena Latest module and JomSocial ( Kunena Latest: How to show JomSocial avatars and link to user profile? )
It is my guess that the Kunena Latest module can only display the avatar images from the Kunena user profile. I may be quite wrong but it's again my guess that if you set the Kunena - Kunena plugin to display avatars, the Kunena Latest module will display an avatar image ... the Kunena avatar image (which is probably not what you want to display).
I would like to see the result of that test. Could you try it for us, please?
Last edit: 13 years 2 months ago by sozzled.
13 years 2 months ago #148114 by Tryweryn
Many thanks for that. Yes when changed it shows the kunena avatar which are all blank as I take it before they were coming from jomsocial. But may i ask why before adding easyblog show module did it show the avatars and when easyblog show was added it stopped? I left it set as u said at www.britmovie.net so you can see the result.
13 years 2 months ago #148134 by Tryweryn
Is the a fix to the latest post mod not getting the jomsocial avatars?
13 years 2 months ago #148138 by Jiminimonka
I have made a test site with Kunena 3 and JomSocial 3.0.1 and the Latest module is displaying the correct JomSocial Avatars. The problem is being investigated however.
Please read the FAQ.
Only one question per topic.
13 years 2 months ago #148158 by Tryweryn
If I can just mention as it may help. The problem did not occur until i placed easeyblog show module on the front page. Removing this module and the latest posts module displays the joomla avatars. Hope this helps a bit.
