Please use other categories for questions about problems that you may be having with your website.
Merged Any plans for a responsive design?
- SinisaKrisan
- Junior Member
Is it responsive?
The use of links to third-party templates, except in the cases of paid advertising that you see at the top and on the right side of this page, is a violation of the terms of use (Sect. 7 - Advertising) within the forum and such links may be removed at our discretion.
We do not answer questions on behalf of third-party developers and we do not encourage the use of this forum for developers to answer your questions about their products.
Oscar2 wrote:
kparadis wrote: Hello!
If you could clarify where to put the class (in Kunena template or site template) or even an example of what it looks like as part of a CSS file, that would be much appreciated. I've been trying to find some other Kunena templates that might be more mobile friendly, but haven't had a lot of luck either.
Same question for me; hope someone can clarify what to do exactly? Thanks!!
- SinisaKrisan
- Junior Member
No one can tell you exactly where to put it until you say exactly:
"I want this and this to be hidden on phone"
and maybe even attach the picture with exact part of the design you want to be hidden.
Geez people...
BTW, i started working on bootstrap-based kunena template.
It is complete overhaul of HTML folder so that might take a while....
Currently there are no bootstrap based templates - i have triple checked, so im kinda doomed to create my own from scratch
/* Fix .visible-desktop in Bootstrap based templates */
#Kunena td.visible-desktop {
display: table-cell !important;
My goal is to make the forum tables and layout readable on a phone. There's a ton of tables in the forums, and I'd like there to be an alternate template for mobile, which there isn't yet, and I get that. I was using JTouch before I upgraded to 3.0 and that was workable, but now I've upgraded. The ".hidden-phone" class idea made me wonder if there was a simple way to do this. But, I'm not sure what is involved to do this. The closest I've found is this explanation: github.com/twitter/bootstrap/pull/3140
Obviously, if Kunena makes a template that works with the phone, problem solved. But it sounds like that might be several weeks or months away.
I was using
