- Thank you received: 127
Question Kunena 7.0.1 stable released for Joomla! 5.4 and 6.0
8 months 1 week ago - 8 months 1 week ago #234507
by Gindi
Replied by Gindi on topic Kunena 7.0.1 stable released for Joomla! 5.4 and 6.0
Just a note:
In Kunena 7, you can find “karma_time” in:
/administrator/components/com_kunena/install/kunena.install.upgrade.xml
/administrator/components/com_kunena/install/sql/updates/php/6.4.5-2025-07-30_remove_columns_users_table.php
/components/com_kunena/src/Controllers/UserController.php
Last edit: 8 months 1 week ago by Gindi.
8 months 1 week ago - 8 months 6 days ago #234508
by xillibit
it seems the upgrade process will do things with socials not work correctly, i will add a fonction under tools to be able to make the import of socials when it has failed during upgrade
Replied by xillibit on topic Kunena 7.0.1 stable released for Joomla! 5.4 and 6.0
Hello,Hello
We have 7.0.1 / 2026-01-30 and get following log MSG/error
"Exception throw at line 489 in file \/home\/sammler\/public_html\/libraries\/vendor\/joomla\/database\/src\/Pdo\/PdoDriver.php with message 42S22, 1054, Unknown column 'socials' in 'SET'"
We get this MSG on all 5.4.2 Joomla installations.
I have looked in the code so it should be handled in upgrade process when you are coming from before Kunena 6.4.0 . I have forgot the params karma_time so it remains in config, it explains why you get this error
Code:( ! ) Deprecated: Creation of dynamic property Kunena\Forum\Libraries\User\KunenaUser::$karma_time is deprecated in \libraries\kunena\src\User\KunenaUser.php on line 700
Last edit: 8 months 6 days ago by xillibit.
8 months 4 days ago #234515
by Denitz
Replied by Denitz on topic Kunena 7.0.1 stable released for Joomla! 5.4 and 6.0
The message is on e.g. /administrator/index.php?option=com_kunena&view=cpanel and in frontend forum index as well.
I updated Kunena from 6.4.7 to 7.0.1
PHP 8.3, error reporting Maximum
( ! ) Deprecated: Creation of dynamic property Kunena\Forum\Libraries\User\KunenaUser::$twitter is deprecated in
8 months 4 days ago #234516
by Leen
With kind regards
Leen
Replied by Leen on topic Kunena 7.0.1 stable released for Joomla! 5.4 and 6.0
Yes, I also have such a message as error reporting Maximum, but if I set it to standard, everything is ok.
With kind regards
Leen
8 months 4 days ago - 8 months 4 days ago #234517
by Leen
With kind regards
Leen
ps
sorry messaged 2x because it seemed like it wasn't saving..
i try this Quick workaround (safe, but temporary)it works on my test site
If you can’t update right now, you can silence the warning by allowing dynamic properties in the class.
Option 1 – Add #[\AllowDynamicProperties] (PHP 8.2+)
Edit:
/components/com_kunena/libraries/user/KunenaUser.php
Find:
class KunenaUser
Change to:
⚠️ This will be overwritten by updates — use only as a stopgap.
ps
Edit:
Find:
class KunenaUser
Change to:
class KunenaUser
With kind regards
Leen
Last edit: 8 months 4 days ago by Leen.
- Thank you received: 2540
8 months 3 days ago #234541
by rich
Replied by rich on topic Kunena 7.0.1 stable released for Joomla! 5.4 and 6.0
docs.kunena.org/en/basics/requirements/requirements-k7-x
docs.kunena.org/en/basics/installation/installation-k7-x
docs.kunena.org/en/basics/upgrade/upgrade-k7-x
