Question Kunena 7.0 stable released for Joomla! 5.4 and 6.0
7 months 4 weeks ago #234346 by xillibit
For now there is an issue when upgradring from K6.4.8 to K7.0.0 which reset all parameters of all components. So for now you need to stay on K6.4.8 untill we publish a new release of K7.0.0.
Sorry for the inconvenience for people which updated from K6.4.8 to K7.0.0 and needed to toubleshoot the issue or restore a backup to go back to K6.4.8.
The following user(s) said Thank You: ssnobben, Gindi
7 months 3 weeks ago #234366 by ssnobben
So dl this from Github and it doesn work there:Install path does not exist.Package Update: There was an error installing an extension: lib_kunena_v@[email protected] installing package
7 months 3 weeks ago #234367 by ssnobben
Ok just saw this and hope to get some news about when its possible to dl and make an update..
Cheers!
7 months 3 weeks ago #234373 by jojo12
I downloaded Kunena 7.0 stable from github tags. But it's not possible to updater from Kunena RC3 and even not on a fresh joomla 6:
Warnung
Installationspfad existiert nicht.
Paket Installieren: Bei der Installation der Erweiterung trat ein Fehler auf: lib_kunena_v@[email protected]
danger
Fehler bei der Paket-Installation.
Kunena Forum Package.
using joomla 5.0.2, cb 2.9.1
7 months 3 weeks ago #234374 by xillibit
We are working on finding a way to fix the issue and there will be a new release after it.
FYI : for Kunena 7.0 you will need to update CB to version 2.11.0 else the plugin integration into Kunena can't work
The following user(s) said Thank You: jojo12
7 months 3 weeks ago #234375 by [email protected]
I also can't install stable and I'm on RC3 but what is CB?
"FYI : for Kunena 7.0 you will need to update CB to version 2.11.0 else the plugin integration into Kunena can't work"
Time to create page: 0.254 seconds
