Question Kunena 7.0 stable released for Joomla! 5.4 and 6.0
7 months 4 weeks ago #234304 by xillibit
Introduction:
The Kunena team is thrilled to announce the stable release...
Introduction:
The Kunena team is thrilled to announce the stable release of Kunena 7.0, a native Joomla extension for Joomla! 5.4 and Joomla 6.x. Kunena 7.0 works on Joomla! 6.0 natvely without the needs of compat plugin.
For people which wants help for translations, Kunena 7.0 files can be translated on crowdin : crowdin kunena
Kunena 7.0 has been designed to work on Joomla! 5.4 and 6.0, the minimal requirements are the followings :
  • Php 8.2.0
  • MariaDb 10.4 or MySQL 8.0.13
  • Bootstrap 5.x
The work done in Kunena 7.0 is mostly to update the code base:
  • Refactor all the code of plugin integration to be in Joomla! 6.0 by working with events and to drop the parts which was planned to be removed in this Joomla! version (thanks to ruud)
  • New: scheduled task purge trashbin (thanks to ruud)
  • Changes on the installer script to be able to work on Joomla! 6.0
  • Make user type on whoisonline widget as links to open the userlist filtered
  • Remove most of the deprecated code
  • Refactor captcha handling conform with Joomla! 5.x and 6.0
New features:
The Kunena system plugin check on registration and on login if the user is in stopforumspam database and prevent them to make these actions
The Kunena configuraion has been converted to be the same that others configurations page in the Joomla! way
Download:
Download K7.0.0 stable here: https://github.com/Kunena/Kunena-Forum/releases/tag/7.0
Donations
Any donations are needed for future support.
The following user(s) said Thank You: ssnobben
7 months 4 weeks ago #234309 by cheshirealan
I am confused.
If this is being touted as a development release and not for use on live sites then why is it being offered as an update on my Joomla site?
Is the description incorrect?
Alan
7 months 4 weeks ago - 7 months 4 weeks ago #234310 by xillibit
The description is incorrect and thanks for pointing it out. I have just updated the news and removed the sentence about developpement release.
Last edit: 7 months 4 weeks ago by xillibit.
The following user(s) said Thank You: Leen, cheshirealan
7 months 4 weeks ago #234321 by jein
Amazing news, thanks for keeping up the good work.
It is sad for me that in my current situation I cannot update Kunena.
We are using Joomla V6.0.2, and I cannot update to Kunena 6.4.8 as it is deemed invalid.
Manual update to version 7.0 is not possible either as this is not supported for the current version 6.3.10 that we are currently on.
I need some advice, please, on how to update our existing version.
The following user(s) said Thank You: xillibit, ssnobben
7 months 4 weeks ago #234322 by xillibit
Make a backup of your site first. Try to update manually to Kunena 6.4.8 by downloading the package from here : github.com/Kunena/Kunena-Forum/releases/tag/6.4.8 , if it's ok make a new backup of your site at this point and make the update to Kunena 7.0.0 like it will be showed in Joomla! updater
7 months 4 weeks ago #234344 by jein
Bonjour Xillibit,
unfortunately this is what I already did - downloading version 6.4.8 and then manually trying to update. This is not possible.
Time to create page: 0.215 seconds
