- Thank you received: 117
Question Kunena 6.3.3 maintenance Release for Joomla! 4.4/5.0/5.1
Regarding the changes in the plugin.js, there is no x_social and no twitter for me, everything is x, even x_social.png is x.png for me.
Btw. in the config.xml I have also changed x-social to x in the content, in the text I have left X_SOCIAL.
My test installation is 98% twitter free and works without problems. There are only two files, twitter.svg and twitter.png in email. In the content there is only "x" and in the text passage "X_SOCIAL".
This morning I created a new test version with a bare Joomla 5.1.2 and a bare Kunena 6.3.3. Only the admin, a user and AkeebaBackup was created.
The Kunena has 33 files in which the term "twitter" is still present.
If I can help to change this, please tell me how.
gindi
I have an another change to renamme the config variables which had the word twitter in it : github.com/Kunena/Kunena-Forum/commit/b4...f0c581b5cdbfbdc4f031
There are couple of others part which have twitter in it, need some work to rename the remaining
Some others hasd been done in developpement version of Kunena 6.4 with that : github.com/Kunena/Kunena-Forum/commit/84...07550d1fc70059b48fa4
Then I created a new test server with Joomla 5.1.1 and Kunena 6.3.2. I then updated the test server to Joomla 5.1.2 and copied the unzipped and modified pkg_kunena_v6.3.3_2024-07-16 into the tmp directory, adjusted the permissions and updated Kunena in the admin directory/system/install/extensions/install directory.
The result was that all relevant entries in /administrator, /libraries and /media were changed from twitter to x.
Unfortunately, the twitter entries were still present in all /components files.
Is there a way to change/update these /components files via the installation file or do I have to change everything manually?
For me this would be a matter of 30 minutes but it would be nice if it were easier.
gindi
I have made more changes in the developpement version of Kunena 6.3.4 to renamme others things from twitter to X : update.kunena.org/nightlybuilds/pkg_kune...4-DEV_2024-08-03.zip and update.kunena.org/nightlybuilds/pkg_kune...4-DEV_2024-08-03.zip
In /media/kunena/core/js/plugins/x/plugin.js I changed the two twitter entries to X. At the moment it also works with twitter, the only question is: How much longer?
In /components/com_kunena/template/aurelia/config/config.xml I changed the entry x_social to x in line 285.
In /administrator/components/com_kunena/src/Controller/TemplateController.php I have changed the entries x_social to x in lines 259/260 and 423/424.
After deleting the browser cache and kunenacache it works perfectly.
Maybe the setting of x-social has to be saved again in aurelia/BBCode.
gindi
- Thank you received: 2535
Is it still not working for you with the dev version? Switching X off and on has been working for me since this fix: www.kunena.org/forum/76-Official-Announc...0-5-1?start=0#231875I have now found a way to switch the X logo in the CKEditor menu bar in Kunena 6.3.3 on and off without major changes.
