Question Kunena 6.3.3 maintenance Release for Joomla! 4.4/5.0/5.1
1 year 10 months ago #231816 by xillibit
Introduction:
The Kunena team is thrilled to announce the maintenance release...
Introduction:
The Kunena team is thrilled to announce the maintenance release of Kunena 6.3.3, a native Joomla extension for Joomla! 4.4, 5.0 and 5.1.
We've implemented native support for Joomla 5. This means you don't have to enable the new compatibility plugin "Behaviour - Backward Compatibility " on Joomla! 5.0 for it to work with Kunena.
Kunena 6.3 has been designed to work on Joomla! 4.4 and later, the requirements are the followings :
  • Php 7.4.1 to Php 8.3.x
  • MySQL 5.7.23 to MySQL 8.3.0
  • Bootstrap 5.1
The work done in Kunena 6.3 is the following:
  • Refactor the backend views to be compatible with Joomla! 5.0 (thanks to ruud)
  • Some bugfixes and refactor of code
  • Replace Twitter by X in all places where it was used and add bluesky social network
  • Replace some deprecated usage of methods Joomla! from in the code
  • Implementation of handle of mentions in a message when using CKeditor
  • Get list of users for autocomplete in search form
Download:
Download K6.3.3 stable here: https://github.com/Kunena/Kunena-Forum/releases/tag/6.3.3
This means that the Kunena 6.2 series is approching the end of life and will be discountinued, with the future release of K6.3 in stable there won't be new versions of K6.2 after that.
Donations
Any donations are needed for future support.
The following user(s) said Thank You: Leen, Pinkeltje
1 year 9 months ago #231842 by Gindi
The work done in Kunena 6.3 is as follows:
  • Replacing Twitter with X in all places where it was used and adding bluesky social network
I have a question: Was Twitter replaced by X everywhere or are there also combinations of X and X_SOCIAL?gindi
1 year 9 months ago #231844 by xillibit
In the key string of language i was set X_SOCIAL but in the content it just displays X
1 year 9 months ago #231862 by Gindi
@xillibit: After this answer, I consistently changed everything that is not text from x_social to x on my test server and changed everything that is text to X_SOCIAL.
Then I did a lot of testing and realised that in the file administrator/component/com_kunena /src/Controller/TemplateController.php in lines 259/260 and 423/424 you have to change the expression X_Social to X so that you can switch the X button in the CKEditor menu bar on and off.
gindi
1 year 9 months ago #231875 by xillibit
I don't understand exactly why you have made this change. For the issue with the icon X which can't be disabled in ckeditor toolbar, you can try with this change : github.com/Kunena/Kunena-Forum/commit/84...68a63bc06fa3f6d8551a
1 year 9 months ago #231879 by rich
The X button works correctly with this change.
