Question Kunena 5.0.6 Released
9 years 3 months ago #183361 by mikerotec
Replied by mikerotec on topic Kunena 5.0.6 Released
You know, whenever I see ' we advice (sic) to update immediately' - I generally expect it to be a security patch.
This doesn't look like anything to write home about - so why mess with it, if it ain't BROKEN?
PS: is this release only for PHP5.6+ ??
9 years 3 months ago #183364 by 810
Replied by 810 on topic Kunena 5.0.6 Released
ok removed the text. it was a copy from a earlier build release.
PHP5.6+ are the only supported php versions, if you have a older version i suggest to update. but it will still be working on older php versions.
9 years 2 months ago #183430 by ovault
Replied by ovault on topic Kunena 5.0.6 Released
Well done very much enjoy this version. Haven't use Kunena for so long so was a treat to see the new theme and layout options etc.
9 years 2 months ago #183561 by fbettiol
Replied by fbettiol on topic Kunena 5.0.6 Released
Hi. Thanks for the update, and the Boilerplate template. Very ilustrative.
However, I think you should include some missing steps (I had to perform additionally) in the README.md file for the 'clean' template:
- Create a new directory for your new template (com_kunena/template/yournewtemplate).
- Copy to that directory the (unzipped) files provided in Boilerplate template.
- Edit files accordingly, as currentluy stated in README.md (mostly, substitute 'clean' by 'yournewtemplate')
- Rename clean.less to yournewname.less in ditrectory assets/less (com_kunena/template/yournewtemplate/assets/less).
Please, consider those suggestions.
Regards.
Fabio
Time to create page: 0.230 seconds
