Question Do users have to register twice for Kunena and for Virtuemart?
15 years 9 months ago #53112 by iLucato
sozzled wrote: What "different" registration page does Kunena send your users too? Perhaps this is a restriction in Kunena because there's no integration with VirtueMart and, in this case, you may need to remove or change the registration link for Kunena. I don't know.
The central question to this discussion is: Do users have to register twice - to use Kunena and for VirtueMart? The answer is no.
After that question was answered, this discussion went off-topic. I repeat, I do not know how VirtueMart works. If you have questions about VirtueMart, please use their support forums .
Hi Sozzled, yup, I know you have mentioned that you don't know about VM and I should contact their support, I'm sorry if I bothered you, but I was trying to see if folks from this thread got to sort it out with some info from them or by themselves.
Regarding the "different" I want to mean, different from VM form, so the Kunena 'Register' link with the @quila patch, points to the link:
index.php?option=com_user&view=register&Itemid=...
and the 'Register' link from my site/VM point to another VM link, so I'll try to check the file kunena.login.php to see if it is possible to change it for the known VM link.
Cheers.
15 years 9 months ago #53115 by sozzled
iLucato: You understand that users do not have to register twice - once for Kunena and once for VirtueMart - because that was what this discussion topic was about.
Now that we're not confused by that issue, nor are we confused by the other issues that resulted in this discussion going off-topic, am I correct in assuming that your question is "How can I change Kunena so that it uses my VirtueMart registration page?" Would that be a fair re-statement of your question? :dry:
15 years 9 months ago - 15 years 9 months ago #53131 by iLucato
sozzled wrote: am I correct in assuming that your question is "How can I change Kunena so that it uses my VirtueMart registration page?" Would that be a fair re-statement of your question? :dry:
Yup, my language barrier always put me in "trouble". That would sound much better. :0)
Talking about it I got to solve it as you can check the suggested thread below: ;0)
Thanks.
Last edit: 15 years 9 months ago by iLucato.
Time to create page: 0.261 seconds
