Question Do users have to register twice for Kunena and for Virtuemart?
15 years 9 months ago - 15 years 9 months ago #52073 by herve123
Hi everybody !
I´m a beginner at Kunena and I tried to look for information here but I didn´t find what I needed.
Let me explain what I mean :
I installed Kunena and Virtuemart on my Website. What I would like is that the member shouldn't have to register twice. At the moment, they have to register to Kunena AND virtuemart (for the purchases).
What can I do to implement just a single registration on my Website ?
And an other question: if I buy a template for VirtueMart, I don't know if the template will also be used for the forum Kunena ?
Thank you very much.
Yours,
H.
Last edit: 15 years 9 months ago by sozzled. Reason: Changed subject to improve search relevance
15 years 9 months ago - 15 years 9 months ago #52074 by sozzled
G'day, herve123, and welcome to Kunena.
I don't know how VirtueMart works as far as user registration is concerned but, because it works with Joomla I would imagine that if people register on your website using the standard Joomla registration procedure then they're registered to use VirtueMart and they've also registered to use Kunena. However, I could be wrong because (as I said) I don't know too much about VirtueMart.
But I do know about Kunena and Kunena doesn't have a "registration procedure" of its own: Kunena uses whatever your website uses for user registration. So, if your users use Joomla to register, then Kunena knows about your users, too. If you use JomSocial then Kunena knows about the users. If you use Community Builder then Kunena knows about the users. Kunena doesn't use a different user table to login to your website. Kunena does keep a table of user attributes (like whether someone is a moderator or what avatar they are using in the forum), just like JomSocial holds information about a user's birth date or Community Builder might have other information about the user.
So, I guess that VirtueMart holds special information about what things the users can advertise, buy or sell on your website. What I am saying is that your users shouldn't have to register twice at your website ... that just sounds uncharacteristic of Joomla.
What do the folks at VirtueMart have to say?
15 years 9 months ago - 15 years 9 months ago #52075 by sozzled
I see that you've added a second question while I was posting my reply to your first question:
herve123 wrote: If I buy a template for VirtueMart, I don't know if the template will also be used for the forum Kunena?
As I said before, I don't know too much about VirtueMart but I would guess that VirtueMart templates work with the VirtueMart extension, just like Kunena templates work with the Kunena extension.
Your question is a bit like saying, "If I buy a set of tyres for my Saab can I use them on my Ferrari?" I don't know. They're both tyres, but they're designed for entirely different purposes and they're engineered to work with completely different machines. That's the same with templates, too.
I doubt that a VirtueMart template would have any impact on Kunena.
15 years 9 months ago #52091 by herve123
Ok thank you very much for your fast answers !!!!!!
It helps me a lot !!!!
Thank you very much, i'll try again and I let you inform as soon as it's good :)
thank you again
15 years 9 months ago - 15 years 9 months ago #53029 by iLucato
herve123 wrote: Ok thank you very much for your fast answers !!!!!!
thank you again
Hi Herve123, I'm facing the same issue. Did you get to solve it? Would you mind to share if so?
I'm trying just to make the registration from VM, but Kunena shows a different registration page.
Even by using the log-in patch (KED - Own Kunena Login) doesn't it use it's own form?
Last edit: 15 years 9 months ago by iLucato.
15 years 9 months ago #53100 by sozzled
What "different" registration page does Kunena send your users too? Perhaps this is a restriction in Kunena because there's no integration with VirtueMart and, in this case, you may need to remove or change the registration link for Kunena. I don't know.
The central question to this discussion is: Do users have to register twice - to use Kunena and for VirtueMart? The answer is no.
After that question was answered, this discussion went off-topic. I repeat, I do not know how VirtueMart works. If you have questions about VirtueMart, please use their support forums .
Time to create page: 0.271 seconds
