- Thank you received: 566
Question A Way To Build Kunena 2.0?
I think that the meaning from xillibit was to say, that in order to make the build, you need to have enough skills to use the tools like git and ant.
Building Kunena is pretty easy. Just install Ant builder, go to /build folder and run ant. Installer moves files around a bit, modifies some metadata and creates smaller zip files from individual parts of Kunena.
If you don't know how to use ant but you're able to pull the files from git, there's another way to do this:
You can pull all the files from git to your existing Joomla installation. Or just copy the all the files into Joomla root folder. In Kunena backend there will be new option to run installer by hand.
Ps. Do you perform git from command line or use some GUI for it? I guess you do.. so which is most simple to use for beginner? I need to share my own code and didn't know how to use this just for now.. ;|
Github tell me to use this help.github.com/win-set-up-git/ . I should use this?
- coder4life
- Kunena Contributor
- Thank you received: 50
I am comfortable enough with command line to build the package.
However, where can I find Ant Builder? Google not showing useful results.
