- Thank you received: 565
Question Few more questions about development
Oky, so you can guaranty a easy upgrade to a native version if I use current version? And I can see Jomsocial is working whit leagcy. Is it possible to ask what leagcy will do fo other components? I know I have to see if for ex. JReview 2 support it and so on. Thanks for the replay by the way.fxstein
Maybe I'll do a Norwegian translation (if I get in to this software)
Let me clarify: Kunena 1.0.x will automatically upgrade to Kunena 1.1.x/1.2.x and the native Kunena 1.5.x.
Whether native or not, the same data gets stored in MySQL - no difference, other than improvements and fixes we will implement along the lines and for those we write the upgrade code.
All you do is uninstall a release, followed by install of the newer release of your choice. And if you skip a version or to, the upgrade will know that and will apply all changes according to the order they came out.
Sorry for going OT - just need to inform that the translation already is WIP
No need to reinvent the wheel, we only need to update and wash the FB file - it will be available during this week.
Excellent! Thank you. We would like to add as many translations to our packages as possible. We have a todo, to make the languages selectable in the backend and later on per user...
