This is a locked category
16 years 2 months ago #59270 by Cerberus
Replied by Cerberus on topic Re: testing k1.6 on IE7
reply works but still getting very odd behaviour like button running away from the mouse
16 years 2 months ago #59271 by Cerberus
No eBay APP ID and/or Cert ID defined in Kunena configuration
Cerberus wrote: looks good to me so far no big error or bugs
B) :( :) :laugh: :cheer: ;) :P :angry: :unsure: :ohmy: :huh: :dry: :lol: :sick: :silly: :blink: :blush: :woohoo: :side: :evil: :whistle: :pinch:
BOLD TEXT Italics UNDERLINED [strike]SRIKE THROUGH[/strike] SUPERSCRIPT SUBSCRIPT
Part of the message is hidden for the guests. Please log in or register to see it.
TEST LINK
<php phpINFO(); php>
COLOURED TEXT
Unable to display Google Map.
HERE WE GO :D
ERRORS:
1) hmm page is slowly runing off my screen to the left hand side as im adding more to this post :(
2) the bbcode help area doesnt change as i move over each button
3) submit button moves to right first time you try and click on it and then works second time
4) bbcode buttons randomly work ( sometimes you click them and nothing happens )
5) map isnt even close to right place ( but then agin as i was given no info from kunena what to put this my be my mistake )
quote work but same odd behaviour as the other 2
16 years 2 months ago #59272 by Cerberus
QUICK REPLY doesnt work at all had to use reply button to post this message instead
16 years 2 months ago #59273 by Cerberus
RECAP of all errors:
6) odd button behaviour they run away from mouse ( no i havent been drinking im at work )
7) quick reply does not work at all
8) attacment visible box and the actual area when you click to add a file missaligned
9) add file button overs over text box next to it at random times
16 years 2 months ago #59295 by sat13734
Hi All,
I have just installed Kunena and really like the features as well as the amount of automated integration that has been done with Joomla.I have a need to create a form as a default discussion forum initiation template which needs to be available anytime the users want to start a discussion - once I capture the basic facts that are needed the discussion board goes to regular behaviour pattern allowing other users to just login and post opinions. Is this doable in Kunena and specifically can I build this form in PHP and integrate that into Kunena and how?
Reagards & thanks for all the help!!
16 years 2 months ago #59418 by robj
fxstein wrote: Really like the new multi attachment feature. Not only does it make uploading several attachments easy - yet compatible with all major browsers, it also allows you to place attachments inline within your text:
Time to create page: 0.157 seconds
