This is a locked category
15 years 7 months ago #84809 by huzzre
Replied by huzzre on topic Test
test
15 years 7 months ago - 15 years 7 months ago #84840 by josm
Replied by josm on topic vrijdagvliegen
afasdf
Last edit: 15 years 7 months ago by josm.
15 years 7 months ago - 15 years 7 months ago #85183 by milas
Replied by milas on topic Video size test
It only works with code "RyUf7r_9yNs" not with link and without 100% videosize
Last edit: 15 years 7 months ago by milas.
15 years 7 months ago #85211 by snilloconator
The widget we made was a few service from www.gametracker.com all you need to do is go to this website and create a free account if you do not already have one, then login and go to the my servers tab and create a new server for your TS3 server.
Then once you have saved this new server you can create different types of website widgets for use, we use the one that requires settings like the width. Set it to 180 px wide for our sites. Then take the code this site provides and embed it into a new user created module with the Editor disable or follow the
The following user(s) said Thank You: Elessar
15 years 7 months ago #85212 by imaaxx
Replied by imaaxx on topic Re: Text overflow test....
You are right is seems to be doing it with the default Kunena template too now.
I seems to do this if you increase the size of the text and then leave off with [/size] tag without adding more text without the size tag.
If you add more text of normal size then it does not do this.
Weird i wonder if there is an easy fix for this.
Thanks for looking into this for me so fast.
15 years 7 months ago - 15 years 7 months ago #85213 by imaaxx
It seems to do this with movies too have a look here:
www.kunena.org/playground/main/85183-video-size-test
test text
Last edit: 15 years 7 months ago by imaaxx.
Time to create page: 0.271 seconds
