- Thank you received: 1
- snilloconator
- Premium Member
- aka snilly
Then once you have saved this new server you can create different types of website widgets for use, we use the one that requires settings like the width. Set it to 180 px wide for our sites. Then take the code this site provides and embed it into a new user created module with the Editor disable or follow the
You are right is seems to be doing it with the default Kunena template too now.
I seems to do this if you increase the size of the text and then leave off with [/size] tag without adding more text without the size tag.
If you add more text of normal size then it does not do this.
Weird i wonder if there is an easy fix for this.
Thanks for looking into this for me so fast.
www.kunena.org/playground/main/85183-video-size-test
test text
