Question Why is the Profile Picture coming from Community Builder so small. Correct on Topics and Posts
15 years 11 months ago #64094 by christian15213
Matias wrote: It's not coding. It's just changing some parameters. :)
components/com_kunena/template/yourtemplate/template.xml contains avatarSizeXWelcome and avatarSizeYWelcome. Just change values in there.
PS: if you want to do it in the right way, make a copy of example directory with diffent name and edix xml in there. Just remember to change template name as well. In that way, you won't loose your changes when you upgrade Kunena.
Are you ready to really dumbify this post? lol... Is Xwidth and Yheight?
15 years 11 months ago #64098 by christian15213
This isn't helping the problem because it is conected to CB someway. i have tried to fire bug it I can't find the source. Can you check it out?
www.primeparty.org
15 years 11 months ago #64150 by Matias
I need to look into this.. It seems that it doesn't work..
Please remind me, if nothing happens.
The following user(s) said Thank You: christian15213
15 years 11 months ago #64302 by christian15213
Thanks,
I keep trying to find it but to no avail. What I might be thinking is.. was a thumbnail created so that is what it is looking for i.e. the 72 x XXX for what it originally created?
15 years 11 months ago #64303 by sozzled
G'day, Christian. Great website and I think there's a lot here that others looking to integrate GroupJive 2.0 with K 1.6 will be interested in learning from you.
You wrote that the thumbnail avatar image issue relates, in some way, with the login feature at the top of your Kunena forum page. If we use www.kunena.com as an example, this is what I see here:
I assume that this is the issue that you are referring to when users are logged in to your site. Is that right?
I haven't experimented with different values in the Kunena configuration settings that Matias was referring to.
If you can confirm my assumptions we might be in a better position to know what we need to look at next.
15 years 11 months ago #64436 by christian15213
sozzled wrote: G'day, Christian. Great website and I think there's a lot here that others looking to integrate GroupJive 2.0 with K 1.6 will be interested in learning from you.
Yep, that is absolutely what I am speaking of. I will search some more to see if I can find the location of the source of the param telling my avatar for the profile pic to be 72 px
Time to create page: 0.212 seconds
