Question Why is the Profile Picture coming from Community Builder so small. Correct on Topics and Posts
15 years 11 months ago #63968 by christian15213
Everything for the pictures in the forumn postings and topics are fine. However, the profile picture is pulling a 72 by 72 px fitting and I don't know where that is coming from... How would I change?
15 years 11 months ago #63981 by xillibit
In which place it's displayed like that ?
15 years 11 months ago #63995 by christian15213
xillibit wrote: Hello,
the welcome login section. I have a square 300 x 300 google adsense in the spot and it looks silly next to it.
15 years 11 months ago #64022 by Matias
It's a configuration parameter inside template. Check your template xml file..
15 years 11 months ago #64065 by christian15213
Matias wrote: It's a configuration parameter inside template. Check your template xml file..
Not too familiar with coding. what should I do exactly?
15 years 11 months ago #64079 by Matias
It's not coding. It's just changing some parameters. :)
components/com_kunena/template/yourtemplate/template.xml contains avatarSizeXWelcome and avatarSizeYWelcome. Just change values in there.
PS: if you want to do it in the right way, make a copy of example directory with diffent name and edix xml in there. Just remember to change template name as well. In that way, you won't loose your changes when you upgrade Kunena.
Time to create page: 0.219 seconds
