Kunena 7.0.8 Released
Question [Merged topic] K 1.6 needs "autodetect" for integration with JomSocial
16 years 1 month ago #56009 by zonedabone
Replied by zonedabone on topic Fatal error after post
Whenever I post on my forums, I get the following error:
Fatal error: Class 'CFactory' not found in /home/rivertraders_/rivertraders.net/administrator/components/com_kunena/libraries/integration/jomsocial/activity.php on line 65
Other users tell me they have no errors, and the post still is put on the forums correctly.
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 90M | Max file upload: 7M
Kunena version detailled: Installed version: 1.6.0-RC1 | Build: 3173 | Version name: Kujadili | Kunena detailled configuration:
16 years 1 month ago #56014 by fxstein
Replied by fxstein on topic Re: Fatal error after post
What version of jomSocial are you running?
16 years 4 weeks ago #56172 by Saibot
Replied by Saibot on topic Re: Fatal error after post
Hi, I have the same / ore similar Problem.
After i Post i get this.
Fatal error: Class 'CFactory' not found in /home/www/web303/html/administrator/components/com_kunena/libraries/integration/jomsocial/activity.php on line 65
or on line 28.
On line 28/65 is: CFactory::load ( 'libraries', 'userpoints' );
My Kunena version is Kunena 1.6.0-RC1
About jomSocial: I have no idea how to check the type of version of jomSocial. If that matters i need help about that too.
Thanks alot.
Tobi
16 years 4 weeks ago #56182 by Saibot
Hmm. I think i solved the problem.
It's somthing about the Forum Config.
I changed the settings on integration: Activity Notifications
And changed it to Auto Detect.
And now, its now longer gets a error after a Post.
It's actually quite simple. Or i'm totally wrong :blink:
Supplements are welcome.
regards
Tobi
The following user(s) said Thank You: avengerxp
16 years 4 weeks ago #56197 by Matias
Replied by Matias on topic Re: Fatal error after post
To see version info: Admin >> Extensions >> Install/Uninstall >> Components
There must be a bug in activity stream detection.
16 years 4 weeks ago #56209 by zonedabone
Thanks so much! Changing the settings to auto-detect fixed everything. This is why I love open source, all of the great support, from great people that really care!
Time to create page: 0.284 seconds
