Question Display Post Count?
This is basically what this whole discussion hinges upon. How to change JomSocial so that it picks up information from Kunena. If the folks at JomSocial can't provide you with an answer, there's your answer. The rest of us gumby users are just guessing.post count is a measure of authority and I'd like the users to be able to see it in JomSocial. What code would I need to add to make this possible?
[strike]There is no "number of posts" value stored in the jos_fb_users table in Kunena.[/strike] You have to [strike]calculate that total with a SQL query from all the messages posted and then[/strike] correlate the Kunena information with the JomSocial user record (if such a records exist ... and I guess they would). I'm sure it can be done but, as I have no understanding of the JomSocial internals, I can't help you.
EDIT: strike out incorrect information
Touché, Matias!
Perhaps this is another good reason why I should stay clear of JomSocial issues. Less trouble for me to get into!
Sozzled: you're wrong. Each user has posts field which contains total posts written by that user.
Well than, that makes complete thing a totally different and new story.
Didnt knew that, thanks Matias.
Now its fairly easy to display posts count.
I have also replied to OP at Jomsocial forums
www.jomsocial.com/forum/index.php?f=5&t=...b_v=viewtopic#p93404
- joomlamanisdaman
Thank you all so much! (Especially WinuxFF)
I'm glad we were to take this conversation and turn it into a solution!
I got it work exactly how I want it to
WinuxFF's code needs a little bit more to actually work (if you copied exactly what he had into php and returned $posts, you'll always end up showing 0).
Here's the full code you need. If you're using the blackout template, change the file in this directory:
components/com_community/templates/blackout/profile.header.php
If you want to place the post count underneath the Karma (if you have it enabled),
After where it says
Add this:
Hope that helps anyone else that has this issue!
We've taken a seemingly complex problem and turned it into a simple one.
Good work guys!
(P.S. I suggest adding this feature to the Kunena website.)
Im trying to optimize my site as much as i can, and reducing the numbers of queries is a top priority for me now.
Is there any API documentation for Kunena 1.6 yet?
