- Thank you received: 5
Question Display Post Count?
I thought i should post this
Since i didnt found any documentation about new API yet, i had to do some reverse engineering and find out how to do this.
It is very simple, and if you use K16 i suggest you to use this, rather than SQL based hack
Again: Make sure you pass the $userid properly
BTW, i would really love to see some API docs ASAP. Reverse eng. sucks, and you know that
You would'nt have any time to help with the API documentation by any chance?
We could need someone that drives that....
I do learn fast, can understand the code when i see it, but trust me, im not the person you would pick to explain how Kunena's API work (if you know what i mean)
Anyway, i feel honored with this proposal and i thank you, but really, someone with more PHP knowledge should do it.
My Best
Sinisa
WinuxFF wrote: Hi people
Code:<?php require_once JPATH_ROOT.DS."administrator".DS."components".DS."com_kunena".DS."api.php"; $posts = KunenaUserAPI::getPosts($userid); echo $posts->total; ?>
I am a massive noob when it comes to all things coding, but I'm trying to learn.
Where exactly and in what file would I put this code in order to make this fix?
Specifically in Jomsocial, you can either use profile.index.php or profile.header.php
Is there a way to fix this?
