Question Errors and Warning when posting a message
16 years 10 months ago - 16 years 10 months ago #37424 by sozzled
I apologise for seeming a bit harsh. If you don't provide us with a link to your website, but only list a couple of errors), it's not easy to tell what you're doing. It's because you mentioned something about your CSS "dying" (I'm not sure what you mean) that led me to leaping to my conclusion about the template.
Justyn wrote:
I have both settings in configuration set to default_ex ...
That's the way it should be! B)
Your error definitely indicates that you have another component or module that's conflicting with Kunena. It's unfortunate that there's no easy remedy in your case. My guess is that the problem has to do with the RocketTheme template as a quick search through this forum will reveal that RocketTheme is often responsible for causing havoc with Kunena. Perhaps you might try uninstalling everything that's associated with RocketTheme.
Last edit: 16 years 10 months ago by sozzled.
16 years 10 months ago #37426 by Justyn
The URL is techmeetup.org if that helps.
I'm actually not using any RocketThemes templates/tools. I'm using a template from Joomla Shack (JS Simplicity).
16 years 10 months ago #37433 by fxstein
What version of JomSocial are you running?
There is an important file missing inside the Jomsocial install. Without that the integration cannot work.
components/com_community/libraries/userpoints.php
Hope this helps!
fxstein
16 years 10 months ago #37434 by Justyn
Upgraded JomSocial and it worked perfectly. Thanks! Now if I could just remember how I got rid of the bullets on my tabs before I'd be in good shape :) I know I had to ad UL LI in a bunch of places, but can't remember where.
16 years 10 months ago #37439 by sozzled
Again, my apologies for leading this topic astray into irrelevant matters (RocketTheme). It's been a bad day for me, I think. :laugh: I saw one reference to RocketTheme in this discussion topic (from someone else) and I associated this with Justyn ... well, there you go!
I'm really happy that you were able to solve your problem yourself by upgrading your JomSocial component. Perhaps you could help us: what version of JomSocial were you using before? Maybe we need a FAQ page to tell other users that version x.y.z of JomSocial causes problems in Kunena?
