Question Errors and Warning when posting a message
16 years 3 months ago #37417
by Justyn
Errors and Warning when posting a message was created by Justyn
I'm getting the following errors when posting a message. Also the CSS dies. Really need some help to get the forum online.
Note: The line number changes message by message.
This error occurs immediately after hitting submit.
Warning: include_once(/home/content/t/e/c/techmeetup/html/components/com_community/libraries/userpoints.php) [function.include-once]: failed to open stream: No such file or directory in /home/content/t/e/c/techmeetup/html/components/com_kunena/template/default/post.php on line 309
Warning: include_once() [function.include]: Failed opening '/home/content/t/e/c/techmeetup/html/components/com_community/libraries/userpoints.php' for inclusion (include_path='.:/usr/local/php5/lib/php') in /home/content/t/e/c/techmeetup/html/components/com_kunena/template/default/post.php on line 309
Fatal error: Class 'CuserPoints' not found in /home/content/t/e/c/techmeetup/html/components/com_kunena/template/default/post.php on line 311
16 years 3 months ago #37419
by franch
Replied by franch on topic Re:Errors and Warning when posting a message
Have you installed Jomsocial on your site ?
If not, go to the Kunena administration and disable Jomsocial integration
16 years 3 months ago #37420
by Justyn
Replied by Justyn on topic Re:Errors and Warning when posting a message
JomSocial is installed, and the integration seems to be working properly. I'd really like to keep Kunena using the JomSocial profiles.
16 years 3 months ago #37421
by franch
No problem on my site using : Kunena 1.5.8 - Jomsocial 1.6.279 and rockettheme template Dominion.
16 years 3 months ago #37422
Replied by sozzled on topic Re:Errors and Warning when posting a message
You are using an old, outdated, unsupported Kunena template that has been causing problems since Kunena 1.0.7b. Do not use it. Please read
There is only one endorsed and supported Kunena template
. That will fix your CSS problems (at the very least).
Have you installed AlphaUserPoints on your website?
16 years 3 months ago #37423
by Justyn
I am using the default_ex template, which is the one referenced in the link you sent. I'm not sure why the errors reference the default template, as I have both settings in configuration set to default_ex - this may be the root of my problem.
I have not installed any 3rd party forum/points related apps, just using the Kunena Core with JomSocial integration.
