Question Users icons...
17 years 5 months ago #20775 by Opinioo
Users icons... was created by Opinioo
i'm using joomla 1.5.11, cb 1.2.1 and kunena 1.5.3
i'd like to know how i can make icons under users avatar appear as it appears here on kunena's site(as born date, gender, skype, location, etc...) ?
thank you
17 years 5 months ago #20781 by xillibit
Replied by xillibit on topic Re:Users icons...
I don't know that you want exactly, this icons are shown if you filled your profile.
17 years 5 months ago #20792 by johnnydement
Replied by johnnydement on topic Re:Users icons...
As xilli says, they are there if you fill the fields in profile.
I don't use CB myself so I don't know about it, but jomsocial for example, does not parse these fields yet, so you need to fill them in your kunena profile, even if it's not used ;)
www.kunena.com/forum/myprofile
17 years 5 months ago #20822 by Spock
Replied by Spock on topic Re:Users icons...
Ok there is a little bit of work in this!
1. Go to Joomla! backend, then go to Kunena Forum >> Kunena Configuration
and scroll down to Integration. Please ensure that both "Avatar Integration" & "Profile Settings" are set to Community Builder
2. Navigate to Community Builder >> Plugin Management >> Forum integration
(i)Make sure that published = "yes"
(ii) set up the parameters on the right (iii) Set Sidebar Mode tot "Beginner field selection"
3. Now go to field management and set-up all the appropriate field listed below the Forum integration Sidebar Mode then go back to Forum integration and select them
Regards
17 years 5 months ago - 17 years 5 months ago #20900 by Opinioo
Replied by Opinioo on topic Re:Users icons...
Regards
Hello Spock,
thank you for your reply
I've done what you said, it seems to work except for gender, it doesn't show it.
My cb field for gender is named cb_sexe, is there something to do with that or is it something else causing that ?
if it's something to do with it, where can i change cb_gender to cb_sexe in kunena to make it work ?
Thank you
Last edit: 17 years 5 months ago by Opinioo.
17 years 5 months ago #20901 by Spock
I don't think this should make a difference :unsure: ? All I could say is
1. Make sure it properly selected in the sidebar of the forum integration plugin
2. Make sure that cb_sexe is published in the field manager.
If this doesn't work you can PM me backend access (for a few mins) to your site and I'll have a look if you want
