Question
Using Kunena signature and subscriptions with Jomsocial profile.
johnnydement wrote: Yes, we have the intention to do so, undortunatelly is a 2 ways work, we've pushed integratin as far as we could, now is for azrul to make jomsocial fields be able to write/read in kunena signature field... we could do the other way around, but is impossible for us, as there's no fixed field for this... I mean, js can make a field be stored in kunena signature field, but kunena can't usa a field from js to store the info, as it doesn't exist yet! ;( is not same as avatar, we're able to pick it, as the field exist in database from the start...
Dunno if I made myself clear
this is total bullshit...
each profile field in jomsocial is identified by a unique id and you can get it´s content by using this id. so simply make an option to use a field id of jomsocial instead of the original kunena signature field and you are done.
now you can make a custom field in your jomsocial profile for the signature and add its id to kunena. all you need is an input field in the integration dialogue in the backend. has to be done once and everything is fine... it is the same as picking an avatr. just saying.
i did this myself for kunena 1.5.8 and it worked without any problem.
This sounds perfect...!
Have you done this for Kunena 1.6 as well - and would you share how you did it?
I saw a neat little plugin that added a tab to JS so that users can edit their K profile, but all links to download go to the KED section, but nothing is there. Wish it still was. Agora's was awesome, then they decided to go commercial, so I switched to K. If anyone knows where to get that nifty plugin, please post the link!
Yes, something like a tab in JS would be great that only contains the two or three unique Kunena settings/pieces of information.
Right now it is not possible for users to navigate from profile Kunena profile to JS profile directly.
There needs to be a proper connect or integration between the two, otherwise users will get confused why they have two profiles.
