Question Question CB and Forum
17 years 7 months ago #10184 by Ufa
Question CB and Forum was created by Ufa
Question please,
How to set that when someone try to register on forum, that he is registered with CB also?
Is it possible?
Thank you
17 years 7 months ago #10188 by sozzled
Replied by sozzled on topic Re:Question CB and Forum
Is it possible?
Thank you
I've read similar requests about this "problem" dozens of times and it's a long time for me to understand what the problem is. I mean, when I read questions about users trying to login or register "on the forum" what have we been talking about?
I believe we're discussing the links I've arrowed in the following screenshot:
In summary, there isn't a problem if you ensure that all new registrations are carried out using the CB registration procedure.
This hasn't been a problem for me because I've assumed (quite wrongly) that people wouldn't register as members on my site using those links! :blush: I haven't had to worry about keeping Community Builder user profile information up-to-date because I assumed that my users would register themselves in a different way, namely, with the CB registration form.
There's a bit of a problem, therefore, with the "Kunena login/registration" links: the assumption is that you're asking your users to use the standard Joomla login/registration functions.
If we follow the advice given by CB, we're supposed to
  1. Use CB Configuration Manager » Registration: set Allow User Registration = "yes, independently of global site setting"; and
  2. Use Global Configuration » System: set Allow User Registration = "no"
Unfortunately, if a user clicks the register link (as shown in the image above) they'll get a HTTP: 403 Forbidden error ... which isn't exactly very helpful! :ohmy:
So there needs to be another solution, one that removes the confusion and directs users to the Community Builder login and, particularly, to the registration procedure. I think the Login alteration discussion provides a few clues as to what needs to be done. I'm going to have a closer look at it to see whether the YOOlogin suggestion deals with the registration issues we've discussed here.
17 years 7 months ago - 17 years 7 months ago #10202 by sozzled
This problem is so bound up with the question about the desirability of choosing Kunena profile data over Community Builder profile data that it isn't funnny! :( Indeed, the more I think about the discussions we've been having, the more I'm reconsidering my strategy of dependence on Community Builder for my website.
You have to ask yourself the question, why do I need Community Builder? What, essentially, does it provide that I can't get from something else? For me, the user registration process is better than anything else I've worked with but, as far as the Kunena forum goes, the CB user data it's practically useless! I wish I could be more supportive, but that's just the way I see it. In other respects, CB provides a fairly neat framework that ties together several components that I employ but, as these can be accessed as menu items anyway, CB isn't an essential requirement.
To answer the question, how to make sure that the CB user registration process is maintained reliably, you need to use the following settings: Kunena Configuration » Integration » Profile Settings = "Community Builder"
If you do this, the links I referred to in my earlier posting will work as intended: your users will use the CB login and registration procedures. However, the downside of this is that you prevent your users being able to change their Kunena profile settings in the forum. Therefore, to address that need, I used the following setting:
Unfortunately this disrupts the way users login and/or register "from the forum".
I don't really know how to give you a definitive, durable solution because, although everyone has different requirements, I'm wrestling with similar difficulties myself and becoming quite disillusioned with the lack of supportive help at Joomlapolis ... :S
If we had a way of configuring Kunena that allowed us to decouple the CB login and registration functions from the CB user profile, I think that would be a help.
Last edit: 17 years 7 months ago by sozzled.
17 years 7 months ago #10320 by Nigel Aves
Replied by Nigel Aves on topic Re:Question CB and Forum
"You have to ask yourself the question, why do I need Community Builder?"
That's a good question! And one you need to answer! I actually looked at things the other way round. What I was looking for was a simple and easy way to have a Facebook / Myspace type "community" (connections between users, messaging) with the additional features of a forum as well.
Yes that really is me 52 or 53 years ago! I wonder in the parrots are still alive!
Now, what we must remember is that Kunena is at the start of it's life and not all the hooks are in place to get data from CB into the forum. A good example is that in the CB user profile you can set up your personal choice for viewing the forum and the footer text you want to use. It worked perfectly for Fireboard but now I seem to have lost the feature. But it will be back I have no doubt.
The key about using CB is (from a users perspective) it's easy to create a profile, you have full control, easy to change and it's a nice environment.
After playing around with the CSS in Kunena and CB it looks identical to the rest of the site (not quite a 100% but pretty close) and it acts seamlessly.
In short. It all boils down to what you need on the site. A Facebook type setting with a forum as an added benefit or just a Forum but with no interaction between users.
17 years 7 months ago #10322 by Nigel Aves
Forgot to mention. You also have to enable their cb.login module (you load it as a Joomla module - mod_cblogin.zip). Without that loaded you can run into strange issues I think the original poster to this thread was seeing. There might be one more thing but my CB manual is not handy.
17 years 7 months ago #10326 by sozzled
We could have a great discussion here, Nigel, and I know that there are several people who would love to be involved. The original question "how do I ensure my users are registered with CB when they use the link on the Kunena forum" certainly begs the question, "does it matter if they're not?" However, to remain on topic, we'd better deal with the specifics of "how to" and leave the issue of why for a different discussion. ;)
